Old 01-26-2011, 01:42 AM
blykins blykins is offline
Brent - I'm not following you. I have a new speedometer cable from ERA but I have a gaping hole in the side of my Toploader that based om my Muncie experience - receives a small housing that the driven gear spins in and the speedo cable coupling threads on to. It should have an o-ring or gasket and is usually held in the transmission with a clamp. You can see it in this photo I think is attached (?).
thanks
Dan
That's usually how my speedometer cables are made for a Toploader. They have the clamp on them, and a little spot for o-ring to seal. The speedometer gear fits on and is held on by a little circlip. Then it all goes up into the tailhousing.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
