turn signal wiring diagram
I had the usual problem with the turn signal switch turning on the collum. I removed it and re-taped the threads. But in the process it all fell apart, springs links etc. Put it back together but it would not work so I bought a new assembly.
Installed the new one but it does not work. The only wiring diagram I could fine on line (for the entire car) is a hand drawn one which shows the basics.
The turn signal diagram is not complete. There are 5 wires coming off the switch but the diagram only shows three wires connecting to anything. There are two wires marked L/H and R/H with colors of Yellow and green. These wires leave the switch go about an inch and end in an arrow ->(not a ground symbol) . Can anyone
tell me where these two wires connect. Or better still does anyone have
a complete diagram?
Thanks,
Jay B
JayB
Jupiter, FL
