Old 02-03-2011, 02:55 AM
Tenrocca's Avatar
Tenrocca Tenrocca is offline
Scenario 1: Go to your engineer with your Classic Revival or Harrison and Manufacturer torsion test.
Scenario 2: Go to your engineer with your Dax or Factory Five, which was built using pretty much all the same parts except maybe suspension and brakes as your Australian kit. Hand it over less the torsion test.
Apart from the torsion test ($2k??) - whats the difference? What other benefit is there if every other part bolted on is essentially the same? If the engineer is doing his job he should still be checking the harrison and CR just as thoroughly as the Dax.
The oversized scoop is more of an issue for me then where its from
