Thread: best bearings
Old 02-11-2011, 12:32 PM
blykins blykins is offline
Originally Posted by garry viohl View Post
For rod bearings for a 482 stroker would you choose:
CB743HN
CB743P
the HN bearings are thinner, is that a good idea for the street? What makes them a performance bearing? Thanks.
You can use either one if it's a Scat or Eagle crank.
The HN bearing is narrow and is usually only used on crankshafts with .125" radii, but it certainly wouldn't hurt to use it on a small radius crank.
It comes down to how much money you wanna spend on bearings. The H series bearings can rack up some cash.
What you may find is that the bearing clearances aren't what you want them to be, so you can mix/match either standard/.001" or standard/X bearings to dial in the clearances. When you're having to buy two sets of H series main bearings, that can get pretty expensive.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
