Old 03-06-2011, 10:54 AM
michel schryer michel schryer is offline
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
It really suck when it happens but it does. It looks like your starter/flywheel are not aligned properly or your parts are wrong or loose. Definitely you have a problem there. Personally I wouldn't try to live with that,you'll always question the reliability. If you don't replace you might cause further damage to the starter or more teeth from flywheel will fly off . Don't waste anytime and get to it. It's part of the game with these cars. Do you have an aluminum flywheel,I read that they're not really recommended,not as solid as steel. People use them to save weight at the track. Good luck and let us know what you find everybody can learn something. I built my own car and that's what I think and would do,so it's just my opinion,cheers. Michel
Originally Posted by Stephan427SC View Post
Hi guys,
while starting my engine today, I heard a "crack" and some teeth flew away from my flywheel...now what to do ? Will I need to replace the flywheel ? Engine has run only 500mls up to now...
Stephan
