Old 03-20-2011, 07:33 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
the reason most will heat the ring for install is that the lengths of the axles means you need a pretty long piece of squarely cut thick walled tube to press it on.
The reason to press it off is because any little nick fron grinder, saw, drill will give you a place for the axle to fail
