Old 04-05-2011, 01:29 AM
Ant Ant is offline
Default K&N Extreme filter top
I have seen a heap of very very fast track cars with the K&N extreme top on them, and they normally have outside air ducted in, not underbonnet heated air!
I would think that KN have made a better flowing air filter where there isnt room for a great 4 -6" high filter, although the extreme filter needs a good space above it for the air to turn in..
Jac, Chaz and Tom you have all hit it right on, firstly tune you carb to suit the filter, then you might be able to make a simple alloy tray with the Moroso foam sealer around it to get free cold air from your scoop, as hopefully separating the under hood pressure should make a difference, and then I would do a some mixture checks. I cant see a major difference in jetting providing your carb is correct for your engine and normally you dont need to go too far from std jetting. I had the Jac Mac scenario of air filter top to close to the bowl air tubes and ended up about 10 sizes rich, until we cut tubes on an angle to stop the air flowing across the carb affecting the way the fuel flows through the main jets, and I went back to std jetting etc!
A J. Newton
The 1960's rocked!
