  #22 (permalink)
Old 04-10-2011, 11:23 AM
Tom Cimino's Avatar
Tom Cimino Tom Cimino is offline
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
I'm using a standard Ford trans mount for a toploader. When I upgraded to the Tremec, I had to install a 1/2" spacer between the trans and and trans mount to locate the tail shaft in the same location as the toploader tailshaft. The chassis has the removable crossmember. The adjusting rings are at the bottom of the shocks.The space between the tire and the fender flange is acceptable, but I wouldn't mind being able to close the gap up a little bit. Everett-Morrison bodies seem to be a little high in the rear.
Ralphy, Thanks for the kind words. Still working on your manual. I'll get it to you.
