Old 04-11-2011, 06:16 AM
einstein1982 einstein1982 is offline
Cobra Make, Engine: Ford Mustang
I wish I could help out further, but it's hard to diagnose/troubleshoot when I'm so far away.
I do know that the majority of hydraulic clutch travel problems is due to air in the lines, but I know that you said that you bled it multiple times.
Did you talk to someone with McLeod's tech support?
Haven't talked to anyone there yet. I had bought it from you so I just wanted you to be in the loop.
I did write them to find out specs and stuff. Didn't know I was getting less then specified travel when I wrote them though
Originally Posted by Great Asp View Post
I assume when you install the hyd throw out bearing that the bleed line is up.
Correct?
E
Honestly, I don't recall, but I'll try to remember. If that would make 0.150" - 0.200" different on travel, I'll put It all back together and try it.
I'll message McLeod with the issue.
