Old 04-11-2011, 07:06 AM
mreid's Avatar
mreid mreid is offline
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
I know you already had this set up, but for others, a hydraulic t/o bearing is not the best choice if you have one. Not only do you have the bleeding issue, but if it leaks, you have a much bigger problem than if you had a slave mounted outside the bellhousing. If you decide to replace your set up, I recommend you use the external slave set up.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
