Old 04-11-2011, 04:28 PM
DaveW's Avatar
DaveW DaveW is offline
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Brad,
The pressings are the same, only the bush hardness is different on the the lower arm and the control arm.
The ute lower arm bush mounted in the knuckle is also different, it is a straight rubber moulding with a bolt tube, where as the sedan has a rubberised version of a ball joint, it can swivel a few degrees.
cradle has a small bracket on it for mounting LSPV (load sensing proportioning valve) this bracket isnt fitted on the sedans but is on utes and sports wagons.
I was going to remove all my bushes and replace with Nolathane or Superpro or something as the VE's are renown for being a bit "squirmy". in the rear.
cheers
