Old 04-11-2011, 09:58 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by Xavier View Post
Earl, get me that pic when you can.
In the meantime I am wondering if this would work? I "think" it is doing what you describe, can be clocked - I just want to make sure the center bolt keeps it from clocking. Can anyone confirm?
http://www.cantonracingproducts.com/...on&key=22-595#
No, not really. The bottom of the bolt and top of the adapter are both smooth.
Once it's tight, and the lines are connected, it shouldn't move. Mine never did.
But, if you're worried about it, put an inside tooth star washer under the head of the bolt. That will keep it exactly where you put it.
If you want to continue using the adapter you have, drill a hole through the outside rim of the adapter, and into the block. Then use a dowel to keep it aligned.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
