Old 04-16-2011, 04:04 AM
blykins blykins is offline
You should have all the parts needed to do that.
The ball is not used for your application. In your package of parts with the Quicktime bellhousing, there should be an "L" shaped bracket and a spacer. It bolts to the driver's side of the bellhousing and a standard Toploader clutch fork clips into it. The slave cylinder should then push the clutch fork towards the rear of the car.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
