Thread: Body weight????
Old 04-18-2011, 03:20 AM
Ant Ant is offline
Default Body weight
I made a lifting frame which braces front and rear of cockpit so no flexing. The frame consists of a heavy tube across between the windscreen side iron location holes, rear cross tube that bolts to the MG door lock dovetail mounting plates and then a large 3x3" rhs up the centre to connect the 2 tubes, welded a piece of flat steel on the top of centre tube with several holes to fit the D Shackle so I could get the balance right. All you need is a 2 pieces of flat on each cross tube that sit each side of the centre rhs and one 7/16 or 1/2 bolt.
I would take a pict but this website wont accept my <39kb .jegs for some reason.
A J. Newton
The 1960's rocked!
