Old 04-18-2011, 06:10 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by RestoCreations View Post
So i have everything set up and i just took my measurements.
Measurements were taken rotating counterclockwise if facing the bellhousing.
I set the dial indicator to 0 at the 12 o clock mark, then rotated-90 degrees counterclockwise 3 times
Readings
90 degrees= -.008
180 degrees= -.018
270 degrees= -.009
Obviously i need to go up a good bit, but what about left to right? Since they are both negative and almost the same, what do i do? Excuse me for being a bit slow concerning this matter. I find it very confusing.
Your good laterally - right on. If I understand your measurements correctly you do need to move the bellhousing up as close to .008 inches as possible.
