Old 04-18-2011, 04:44 PM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Default Could use a little help dialing in the bellhousing
So i have everything set up and i just took my measurements.
Measurements were taken rotating counterclockwise if facing the bellhousing.
I set the dial indicator to 0 at the 12 o clock mark, then rotated-90 degrees counterclockwise 3 times
Readings
90 degrees= -.008
180 degrees= -.018
270 degrees= -.009
Obviously i need to go up a good bit, but what about left to right? Since they are both negative and almost the same, what do i do? Excuse me for being a bit slow concerning this matter. I find it very confusing.
Old 04-18-2011, 04:56 PM
xlr8or's Avatar
Check this link:
http://www.hurst-drivelines.com/file...206-15-09A.pdf
Old 04-18-2011, 07:10 PM
DanEC's Avatar
Readings
90 degrees= -.008
180 degrees= -.018
270 degrees= -.009
Your good laterally - right on. If I understand your measurements correctly you do need to move the bellhousing up as close to .008 inches as possible.
Old 04-18-2011, 09:53 PM
Chris,
I'm sorry I haven't been able to get back to you, it's been one of those days...
Is everything torqued down? I'd try it once again, I think maybe your dial indicator is either overtraveling or you hit a bump on the register bore.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 04-19-2011, 09:50 AM
mkassab's Avatar
Cobra Make, Engine: Unique 427 S/C, 427ci
Chris,
Brent... "it's been one of those days" !! You mean working on my BOSS 9 engine is stressing you out?
Hey everyone.... believe me, Brent is loving this Boss 9 build!!
Mark
Unique 427 S/C, B2 Motorsports 427ci SBF, TKO600, Jag IRS 3.73 Posi, Avon Tires.... and so much more http://www.uniquecobra.com/forums/forumdisplay.php?f=68
