04-20-2011, 05:20 AM
wa
Originally Posted by craigayl
Silverback51
That is not a factory install.
From the factory the car is delivered with a spring that pulls the pedal back in the foot well. The only other springs are what are attached to the carburetor.
I also see your linkage has seen some excessive bind because of the way the bell crank lever is bent/twisted. When adjusted properly, you shold be at WOT at the same time as the gas pedal hits the floor. If the carburetor gets to WOT before the pedal gets to the floor, you will bend linkage.
Craig
And here all this time I thought that spring set up was from the factory. Thanks for the lessons learned Craig.
John Hall
