Old 05-17-2011, 05:17 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Wiring
If your horns still blow with the relay removed, you have a wiring issue. Either something is shorted out or is mis-wired.
If the horns only blare when you plug the relay back in, try a different relay, it may be welded closed. If that doesn't do it, back to step one - wiring issue.
Good luck chasing it. It will probably require unwrapping the harness and tracing wires since you don't know if someone may have spliced in something in the middle
Good luck
Paul
www.65shlb.com
www.prdcrrct.com
