Old 05-18-2011, 03:13 AM
Modena's Avatar
Modena Modena is offline
Originally Posted by Krait View Post
Insulated connectors when crimped use the deformed the plastic skirt as a strain relief. If the plastic skirt is removed and heatshink is used some strain relief may be provided but the mechanical style is really the way to go.
If uninsulated connectors are deemed preferable then the type with the strain relief clamp (pictured) should be used, then the heatshrink is simply providing electrical insulation as designed.
A different crimper is required as well.
this type look good, and with heat shrink I can see them providing a good connection with good strain relief - what are they called, and what is the crimp tool called?
Ben in AU
