Old 06-06-2011, 05:52 PM
elmariachi elmariachi is offline
Originally Posted by UKjohnnycobra View Post
Elmariachi: I have an IR thermometer. Ill check the delta between the top hose and bottom. If I remember, when I looked at this before, it was about a 20F difference (seems low to you?) but I'll confirm.Oldog: i dont think its the gauge because it runs at the right temp when the car is driving. Also it should read higher than the stat, no? Once the stat is open by definition the temperature is 160F or greater.
On my big block car I have a 180*F t-stat and the temps are 190*F on the top hose and 145*F coming out the bottom. This after installing the infamous $50 Taurus shrouded cooling fan, which moves 3000 cfm on low speed and something north of 4k on high.
Fan discussion here: Taurus Cooling Fan Install
Use the temp gun on your manifold or wherever your gauge sender is mounted and that will give you a good idea of your dash gauge accuracy.
