Old 06-11-2011, 09:45 PM
Zedn's Avatar
Zedn Zedn is offline
Default LS sump measurement?
Gday,
I am after measurements for sumps from LS engines. If you have an LS engine in an easy to reach spot, would you mind throwing a tape on it for me to check the overall outside depth (bottom of the drain plug casting)?
I have an LS3 which is about 185mm deep. I think the LS1 sumps might be around 125mm, but im not sure. Looking for measurements for LS1, LS2, L76 and L98.
I have my motor sitting in there at the moment, but it will be a very tight fit for height and i would like more clearance under the car.
Cheers.
Liam
