Old 06-22-2011, 11:28 AM
Mike Huddart Mike Huddart is offline
Originally Posted by markha View Post
I have read a lot of people on here that seem to like the Dynatek 8 stack EFI setup for looks and performance.
But from pictures that I have seen, it looks like the injector angle is 90* to the throttle body? Is that true? Is it not an issue?
Mark, ( is this correct ? )
We are the European distributor for Accuform ( was Dynatech and Dynaformance ) and as such we have probably fitted and commissioned more of these kits than anyone else.
The injectors do not come in at 90 deg, they use the long plastic EV6 injectors which reach from just about the underside of the top plate to just above the butterfly. Not sure of the angle but it is fairly accute and when the butterflys are open inject more or less straight down the port, the angles are slightly differant from one half of the TB to the other as getting everything installed under the top plate is a bit tight and the injectors have to be angled away from each other.
In practical terms none of these compromises seem to matter much, we get great results and even pass our quite strict Cat tests with our kits
If you need any more info let me know, Mike
