Old 06-24-2011, 07:00 PM
leroy17's Avatar
leroy17 leroy17 is offline
Merv, I was just looking at them as an easier option than full subframe removal.
This is most likely a stupid question but when fitting an adjustable camber upper arm are you guys replacing the factory camber bolt as well or retaining it?
I have been looking over the drift work kits for adjustable upper and lower arms, toe adjustment and the tie rod kit......... that should be enough adjustment for most purposes.
