Old 07-01-2011, 01:38 PM
07cob's Avatar
07cob 07cob is offline
Gents
Many thanks - some good ideas here. I will have a look at the Summit/Sideshow kits for the controller. I suspect that will be the way to go. I would like to keep the adjustability.
Paul, this is the adjustable thermostat for the cooling fan. The ECU temp sender is in the inlet manifold.
Dimi, did the tube you soldered actually penetrate the cooking system? This sounds like a very simple solution!
Stephen - the override switch is definately on the list of upgrades!
Merv, much the same as you but I have the engine out so will do the rear main seal and fix a leak in the gearbox. I will post details later.
Thanks again to all.
Geof
