Old 07-06-2011, 07:05 AM
wedgerton wedgerton is offline
Cobra Make, Engine: FFR MKIII 347ci stroker 450hp
Originally Posted by 392cobra View Post
Wayne,
Pretty common problem.What they recommended would be vent baffles not jet extensions on the secondary.
Baffles help with prevent the fuel from sloshing thru the vent in the carb throat.Causing the stalling problem during hard braking.
The Jet Extensions help to prevent fuel starvation in the secondaries from the jet becoming uncovered on hard acceleration.
Example : Holley 26-89 - Holley Fuel Bowl Vent Baffle - Overview - SummitRacing.com
You are correct. When I originally called the engine builder I thought he told me jet extenders but when I called him back, after your post, he said yes it should be the vent baffles. He probably just mispoke the first time or I mis-listened
Thanks for the feed back on this it helped, I hope.
Wayne E
