Old 07-10-2011, 03:13 PM
Default couple of other thoughts
Desmo If that fluid is trans fluid, it's the front seal or the housing to the case. Dave has gaskets to replace if needed. We used to just clean everything and RTV the housing to the case. Just check and make sure the input shaft doesn't have alot of side to side play. Ask Dave for the spec.
Check also that the bellhousing is true to the crank of the motor. I see what looks like blueing of the end of the input shaft. I put a thick grease in there to help keep this lubed and free spinning. Just a thin coat. Thats it for now. Rick L.
