Old 07-19-2011, 05:47 AM
Zedn's Avatar
Zedn Zedn is offline
Liam,
A good trick to attain a complete coverage is to have a 'spotter' with a bright lamp standing by. Get them to have a look around after each coat/pass... as well as having a "spray check sheet". Use 'paint' or something similar on your computer and print up a sheet with a checkerboard design ( squares about 10mm) Black and White checks and then stick it near where you are painting. As you put down a coat of paint do the same on the "spray check sheet". When the sheet is completely covered you have the same on the project.....Then, if there is one side of the panel that is poorly covered. You can blame the 'spotter' !
Thanks for the tip Rob. Thats a great idea with the checkered sheet. I dont have a spare 2pack mask for the spotter though.
A big part of the problem is getting into all the nooks and cranneys in the chassis. Going to use my smaller gun this time. Also the lighting wasnt good in the garage after making a booth out of plastic. I have a halogen spot light but it is really difficult to spray with it shining straight on becuase it kind of shines through the paint and you cant see the texture.
Its a beautiful colour i am spraying. It is a motor bike colour with a lot of pearl in it. The only problem is that the pearl plays tricks on you whilst spraying. When you look side on the coverage looks great, but when it gets to the angle where it flips you can see straight through it. Im sure it should have a ground coat but the shop says the formula doesnt list one.
It did 3 coats of blue on the weekend and im not happy with it so now i am rubbing back the clear and will spray another 4 coats of blue with a bit less thinner before shooting it over with clear again. I am going to spray it outside this time if we ever get good weather again. Not too worried about a few little spots of dirt when it is the chassis. I have a booth lined up to spray the body in.
