Old 07-24-2011, 03:37 PM
DAVID GAGNARD's Avatar
Originally Posted by SuperHart View Post
Well, just add my post to the "Coulda, Shoulda, Woulda" Department. This is a prime reason why you should always stuff an old rag into every open hole before you work. The law of probability states that a nut, bolt, washer or any other foreign object, when dropped, will always end up in the most inaccessible and inhospitable place it can find. Been there and done that more times than I care to admit to.
Zaactly,learned that lesson a long time ago when putting an engine together. Luckily,it was still on the engine stand,had to turn (rotate) the whole engine on the stand a few times to make it fall in the oil pan to get it out....
Since then, I ALWAYS stuff a clean shop rag in every hole possible.....
David
DAVID GAGNARD
