rear end
Ok I've looked for the answer on line and can not find one. I have the rear end in the frame. When I measure off the frame to the end of the end of the axle housing there is about 1/16" difference side to side. Is the normal and when I measure from the inside of the frame to the center of the pinion gear it's off center by 1/4". Again is this normal? Other than that moving along good, engine will be ready in 3 weeks or so. Getting ready to order tranny TKO 600. I'm really enjoying this build. I'm taking pics as I go, will post them soon. Does anyone use solid motor mounts? I thought about using a front engine plate and a solid trans mount. What's your thoughts.
Dave
