Old 09-24-2011, 06:48 AM
FWB's Avatar
FWB FWB is offline
so based on that, keyed hot does not go anywhere near the switch. is that your black wire? test it for juice.
there should be only 3 wires coming out of the switch, 4 if you count the washer feed ,low speed high speed, wash and ground.
the connector on the motor should be grounded(the odd blade in the plastic) see pic of connector(earth)
Fred B
