Old 10-24-2011, 07:51 AM
FWB's Avatar
FWB FWB is offline
did you buy the ersons to replace the blue jobbies that were breaking?
if you have the .090 restriction you may need to go to the .060 to keep the oil regulated. this may be a dumb question, but are the shafts ok? were they worn bad when you swapped rockers?
i don't mean to harp on the oil......but the VC's and the baffles may just be a symptom of the real problem.....and brent, i'm sure will have the correct solution there for you...
Fred B
