Thanks for the tip on the Mike Forte
oil pan adaptor, Bob! I had figured I'd have to cobble up a bunch of brass adaptors, it's good to know that someone else has taken all the guess work out of it for me.
Originally Posted by bobcowan
Good operating oil pressure should around 45psi or so. It will drop a bit at idle, but not too much. Too much oil pressure is not necessarily a good thing. The oil should be "thick" enough to maintain proper oil pressure. Whatever viscosity that might be. In the winter, you should run a fairly low winter weight. Since we rarely drive our cars in sub-zero temps, a 15W is probably fine.
I use 5W-30 true syntheitc year 'round. Maintaining proper oil pressure isn't a problem. When hot and on the track, it runs about 45-50psi. I tear the engine down every two years. The bearings look excellent after two years of abuse. I replace the bearings (just because) but I'v never had to cut the crank. Obviusly, crank and bearing wear is not an issue.
I suspect my engine has a high-pressure oil pump and that it is already at the limits of the relief spring once I get the RPM's above an idle. I would rather use a high-volume pump, but for now it has what it has, so I'll deal with that until it is time to tear it down. At this point the only place where I have any oil leaks is the valve cover, so I know the pressure is not adequate to force oil past the front/rear seals, etc. It is totally street driven, and rather tamely for the most part as I know the local police would love to nail me for anything they can....I was on my way to a car show in Beaumont, TX and was stopped by a DPS officer for having an expired registration. It took 2 minutes to show him my receipt from the new registration the day before, but it took an hour to get away from him after that, he was a "car guy" too and wanted to talk cars.
As for the
synthetic oil, I've been a bit reluctant to use it since I put it into a new Mitsubishi Eclipse I bought for my daughter (after 12,000 miles with normal petroleum based oil) and the car developed a severe oil consumption problem. I know it would be better from the standpoint of heat tolerance, and probably from the standpoint of wear protection, but that little experience I had with the
synthetic oils has me afraid to try again.
Once I get the valve-cover gaskets and the thermostat replaced, I'll experiment around with oil viscosities to see which meets the guidelines you posted. I don't mind "only" 45 at full pressure, but would want at least 30 at an idle when at operating temperature.
I once had a '66 Cadillac with the 429CID V-8...the pressure required to illuminate the "idiot light" for low oil pressure was 8PSI, no kidding! I mention that b/c I guess it just illustrates how little oil pressure is required to maintain a decent film on the bearings and other operating parts, but I would still like for the low RPM oil pressure to be better than "minimum".
At some point I plan on installing an Oberg oil filter "downstream" from the canister filter...right now I use Purolator's "99%" efficiency oil filter (reportedly designed for the
synthetic oils), but I like the idea of the Oberg as a "fail-safe" should the bypass function on the canister filter be triggered, and particularly if I were to install an oil cooler in the scoop below the fishmouth (radiator opening).
Cheers!
Dugly
