Old 11-16-2011, 01:54 AM
blykins blykins is offline
Lots of stroker crankshafts out there for the FE's now. One of the most common combinations for the 427 is to do a 4.250" stroke, which puts you at around 482ci.
The Sidewinder intake would be a nice dual plane intake to use for the street and you could even use an aftermarket EFI, throttle body style system on it.
If you don't have cylinder heads, a nicely ported set of Edelbrocks work great.
Your block setup with a Scat crank/rods, Diamond pistons, Edelbrock heads, and a hydraulic roller cam (if your block is drilled for it) would make a very powerful and streetable engine.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
