Old 02-12-2002, 09:13 PM
wadesdad wadesdad is offline
Cobra Make, Engine: Former owner of an A&C
If you're not reusing the master cylinder, try applying some heat, but don't blow up your car in the process.
If you are reusing it, you may need a "Line Wrench". It's an open ended wrench that goes 3/4 of the way around a fitting so you do not round off your line ends. I've only seen them on Matco or Snap-On trucks. There must be a retail store also.
Good luck.
