Old 11-28-2011, 06:14 PM
cobraduke cobraduke is offline
Cobra Make, Engine: SOLD Excalibur, '94-'95 5.0 EFI, Edelbrock heads, E303 cam, 1.7RR, Cobra intake, 24lb injectors, 93 cobra ECU, 65mm TB, hi flow cats.
Default Wood Steering Wheel
Originally Posted by tcrist View Post
I have the Chevette column and a Momo (I think that is what is says)steering wheel. The steering wheel has six screws where it screws to the adapter, if that helps.
I have the same Chevy S-10 column and Nardi wheel, same six mounting screw set up. Before I put on the Nardi, it had a Momo. I still have the Momo, but I wanted a bigger diameter wheel. I think I have a 15 inch now and the Momo is about 13 inches. I'm not positive, but I believe the Grant uses a different wheel mounting. If you get the right adapter, any of these can be made to fit.
Mike
