Thread: SC 540 Aircon
Old 11-30-2011, 12:46 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
What number is your car....I think from number 28 on you can use the ford unit in the cockpit they modified the chassis to suit .....if its earlier than 28 you will have to buy the full kit off DRB ...either way you have to use the re location kit for the compressor
