Thread: SC 540 Aircon
Old 12-03-2011, 02:33 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Bigfish the top of the tunnel continues at the same height as where the shifter is...it doesnt rise as yours does ..also the middle piece of the firewall has gone forward approx 75mm....the 50 x 50 rhs that runs under the top from side to side has been shifted on top... drb sent me the revised changes and advised me not to do it...but im doing it anyway!!! if theyve made it work it can be done ...Im going to remove the aluminium sections then fit the motor and box and aircon unit and rebuild the aluminium to suit....
