  #27 (permalink)
Old 12-17-2011, 10:53 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
I just remembered that I cut about an inch off the bottom of the filter base to clear the hood.
That is why I had to replace the foam with a more open filter material, because at high Rpm the foam does not pass enough air and gets sucked into the carb. I used the blue home filter stuff from home depot , with trepidation at first, but as I said its been on there for a long time. Now I also know that this filter material is not as good at filtering as a k&n but with the extra in the scoop there are no stones coming in the scoop.
