| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
12-14-2011, 11:27 AM
CA
Originally Posted by RET_COP
K & N just told me that my red gauze 11 7/8 x 8 3/8 oval flows only 387 cfm ! yikes !!.
I have no room for anything else. I like what mdross1 did and I have thought about this, but it's not in my plans for now.
Those Edelbrock triangle foam filters claim 1000cfm. Does anyone have any positive information on this. Maybe use some flame retardant spray.
Get this, they also said that on a 14 x 3 round red gauze filter, the difference between the extreme top and a capped top is 200cfm
Lou
I have an Edelbrock 1000cfm....:threw the foam away and used ac filter from home depot.and also used the same in the scoop and brake ducts......no more stones on the intake.No restriction whatsoever. Been there for at least 5 years.
12-14-2011, 11:43 AM
tx
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
Got pictures of what you did to enlighten the rest of us?
12-14-2011, 04:16 PM
Me
Originally Posted by TN Shelby Cobra
Don't really care! Fast enough like it is!
The very reason why will all march to a different beat.Nothing wrong with anything we do to our cars afterall whose names are on the titles.My background is in racing been doing it most of my life so total performance drives me.These cars have it all know matter what they breath through.Gotta say I really hated to take the Stellings off the motor, hated even more to cut a perfectly good hood.
12-14-2011, 05:03 PM
RI
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Chanmadd,real nice idea, mind if I borrow it
Hotfingers , the xtreme top, I can see where it would be good on a dyno with air going straight down on the air cleaner but in a driving situation with air going across the top, I have heard that it hurts flow. What do you think? Have you any data on that.
Lou
Lou
12-15-2011, 01:05 AM
Oh
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Lou, the only thing I can add, is that at the track I run the same times, with or without an air filter. After seeing that, I don't bother taking the filter off when at the track. BTW that's an 11 inch filter.
Jack
XSSIVE .....
12-16-2011, 07:59 PM
TX
Mine is a 9 inch by 2.5 or 2.75 thick K & N, flat base with an Xtream top. No difference in the chassis dyno with it on vs off. Love it!
Updated my original post..
Gary
CAV GT40
12-17-2011, 10:53 AM
CA
I just remembered that I cut about an inch off the bottom of the filter base to clear the hood.
That is why I had to replace the foam with a more open filter material, because at high Rpm the foam does not pass enough air and gets sucked into the carb. I used the blue home filter stuff from home depot , with trepidation at first, but as I said its been on there for a long time. Now I also know that this filter material is not as good at filtering as a k&n but with the extra in the scoop there are no stones coming in the scoop.
