Old 12-29-2011, 07:40 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Thanks Dave,
You may never find the turd that went through the cylinders but check in the intake and exhaust. I hope the left bank is not hurt any worse than what you already found on the right bank. A little solvent poured behind the valves will quickly check for bent valves. A new 540 or 572 would sure test all your suspension modifications. The 540 combo has been refined to a volumetric efficiency level that pump gas yields 700+ flywheel HP.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
