01-12-2012, 09:18 AM
NH
Great question:
Front:
You can adjust the camber via trunion adjustment up or down. It is also fairly common to add adjustable A-arms as that helps avoid spring length changes. Also aids in caster adjustment.
Rear:
I suggest adjustable A-arms as without you can only change the length of the spring. This also solves caster issues..... Otherwise the frame mount sets caster.
Adjustment points for 289:
A) Spring length
B) Blocks to lower off the A-pillar
C) Adjustable A-arms big plus for cast and camber
D) Trunion position (front only)
Most shops will run and hide...... There are shops scattered about but few and far between. I suggest trial and error with simple level and tire wear observations.
