Old 01-20-2012, 09:56 AM
Hydramada Hydramada is offline
Originally Posted by Dana E. View Post
I have the canisters on order from Kirkham but I still haven't decided whether to do braided or hard lines from the canisters. Are the fittings at the master cylinder pressed into the rubber seal or are they threaded into the master cylinder?
Pressed in. It takes some effort to remove the old master cylinder reservoir due to the ungainly location. Just lube up the rubber grommets and the fittings pop in pretty easily.
I went with braided lines for convenience. I did not want to be bending lines and then trial fitting them around the brake power booster for hours and hours.
Hydramada
