Old 02-21-2012, 08:38 PM
tkb289 tkb289 is offline
Originally Posted by jhv48 View Post
Make sure if you have a breather on the other valve cover (not the pcv side) that it does NOT vent directly to the outside air. It must vent to the air cleaner.
If you do not do this, you will fail and have to go back after you have fixed it.
And from what I understand, the hose needs to be stamped 'Anti-Smog / PCV Hose' or similar verbiage. Unmarked hose, heater hose, fuel line and such will not pass.
