Old 02-25-2012, 01:05 PM
OhBuoy OhBuoy is offline
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
The tank itself is rought 19 inches long and 6" diameter. There is a 5" x 15" mounting plate that raises the tank only slightly. There is an activator cap that I need to locat which goes on the end of the tank. It probably adds another 2" or so to then length. If you need more exact measurements (the tank does taper at one end, so you could possbly leverage this if you were in a really tight spot. I was going to put that end by where the roll bar was. If you want to come over one night and have a look, let me know. I need to find the activator cap. I did find the two nozzels.
