Old 03-13-2012, 12:11 PM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Ok, here's the measurements from mine.
I am running 15 X 7 and 4.5 backspace with 235/60/15 on front.
Also running 15 X 8 and 4.5 backspace with 295/50/15 on rears.
From frame to face on front is 12 7/8" and 7 3/8" on rear.
The rear is slightly tucked in on mine so it could come out a little. If you are running 10" on the rear, yours will most likely stick out a little.
I had a rub on my drivers side that I had to fix so you don't want to go farther in.
