Old 04-01-2012, 08:29 AM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Originally Posted by mdross1 View Post
Be careful how much you lower your engine because of a lot of things especially road clearance.After talking with K&N about what I needed to feed my 460 all the air it could injest unrestricted through an Edelbrock Perf RPM, a 14"x3" with Extreme top was the solution.
Mine is a 9"X3" with the X-Stream top, too. Right now, it sits up into the scoop with 1/4" top clearance, not much more side clearance. Since my scoop is too small to hold an 11" or 14" filter, I am pretty much stuck with the 9".....
I think I'll call K&N, too. My 302 is mostly stock, only converted from EFI to carb. Maybe with the X-Stream filter top I could provide all the air the engine would need with a 2 1/2" filter, maybe even a 2".
I certainly don't want to start chopping mounting horns off the frame if I can manage any other way....just want to make sure the engine will get the air it needs.
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
