Old 04-14-2012, 05:07 PM
Curt C.'s Avatar
Curt C. Curt C. is offline
Cobra Make, Engine: Classic Roadster; 351W
Default Relay recommendation for neutral safety switch needed
I want to install a neutral safety switch on my Classic Roadster which utilizes a Tremec 3550. The transmission does have a neutral switch. I believe that the wiring would encompass running the starter wire through the relay continuing on to the starter solenoid? Then run another wire to the transmission neutral switch and one more to ground? Sound right? What relay would I need? Part number? I appreciate the input.
