Old 04-21-2012, 02:45 PM
DAVID GAGNARD's Avatar
Originally Posted by philminotti View Post
David-
You won't be able to have any advance without the Ford EEC connected to it. The distributor outputs a cam sync signal called PIP which the EEC uses to calculate advance. The EEC then sends a signal back to the ignition module called SPOUT which contains the timing advance information.
So to make a long story short, you could get it to work, but with locked out timing only.
phil
Thanks a million,that's what I was afraid of and not what I want (locked timing)......so,now it's back to the drawing board.....
I guess the next best thing to do is use this distributor as a core and get a rebuilt one for an early 80's Mustang GT with a carb.....
any other suggestions other than MSD????? I'm burnt out on them.My car sits for sometimes a month or more and have had corrosion problems all the time, it gets old having to pull the cap off and clean all the contacts and mechanical weights to get it to work right...
David
DAVID GAGNARD
