Thread: 302 starter
Old 02-22-2002, 11:57 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Sounds like a tight squeeze if the starter solenoid hits the frame. I've never had much faith in OEM Ford starters, changed too many of them. Got a Powermaster (#9162), ~$150 US from Summit (summitracing.com). This unit fits the 157 tooth flywheel/302 bellhousing. 1/3 the size & weight of the Ford piece, should give you more clearance. Not sure how one obtains US made parts in UK, but I do know getting UK made parts in US is pretty easy. Look up a guy named Wayne Roper at europaspares.com and see if he can help.
