Thread: brand new guy
Old 05-22-2012, 04:44 AM
daverascal daverascal is offline
Cobra Make, Engine: acc
Default msd
Had a bunch of problems with the 6al msd box. Sometimes it would start other times not. Changed out box checked all wiring and grounds, problem still there. So I pulled out the entire system and put in a Mallory Unilite works great. So next I tried out the trans set up. I adjusted the clutch until there was no slack left. Not enough I could not get trans into gear. The throw out bearing arm hits the bell housing, plus the throwout bearing has not slack between the bearing and pressure plate. So I think I'll change out and go to a hyd. throwout bearing. Seems I figure out one problem another surfaces.
Dave
